7 members (Gdads51, TUTS 59, WICruiser, Phak1, Wheelie, Bill Hanlon, 1955 1 Series),
101
Mod | | | Forums66 Topics128,187 Posts1,057,325 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 283 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 283 | On a 1958 1/2 ton with a 283 and a Rochester down draft, 2 barrel, carb. Where is the vacuum port supposed to be so one can attach a vacuum gauge to adjust the mixture?
| | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy GMCAMARO, If I am remembering correctly there should be a port on the back of the carburetor down near the intake manifold, I think it is a 1/4" pipe port, hope that helps. | | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | Most of the intake manifolds have a port about halfway between the carburetor and the distributor. That one has full manifold vacuum and also serves as a connecting point for a PCV valve, power brake booster, etc. Jerry
| | | | | Joined: Oct 2008 Posts: 283 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 283 | This is interesting, behind the carb near the manifold was 1/2" bolt. I have no vacuum advance and looks like where it goes. Then I remembered a stud with a hole in it, holding down the carb. When I looked in the assembly manual and repair manual I could find no information. The net has shown me these were primarily for cars. Either I have the wrong manifold or the factory was not consistent and mine got the stud. | | |
