1 members (WICruiser),
69
Mod | | | Forums66 Topics128,167 Posts1,057,022 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | I am replacing tie rod ends and getting ready to do an alignment. When I put the new ends in the old tie rod, it gets REALLY hard to thread at about 3/4" away from the length I need on each side. I don't want to ruin these new ends. Is there a source for a new 1 ton tie rod? I tried Classic Parts, LMC, Brothers and Jim Carter with no luck. Worst comes to worst, if someone can tell me the thread information I can have RuffStuff Offroad fabricate one.
1953 GMC 1-Ton Pickup with 350 and 700R4
| | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | I found that the threads are .812-18. If nothing else I found some fab shops online that may fabricate one.
| | | | | Joined: Apr 2017 Posts: 480 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 480 | When I needed to replace the tie rod on my 53 one ton I got them from NAPA, took a couple of days to get them in. Of course, that was 10 years ago, but you might check.
Tim
I am currently digging back in to a 1953 3800 (one ton) with a nine foot bed. I've owned it since 1979, and drove it until 1982 (or so). My wife got me involved in restoring it back in 2002, got the body removed and the frame redone, then things came up. Now I am retired and starting again. If anyone is interested I have photos on Imagur ( https://timwhiteblues.imgur.com/ ). I live way back in the woods in the Ozarks on 40 acres at the end of a 2 1/2 mile private road. Tim
| | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | Napa can get the ends but not the rod. I did find a tap for the right hand thread if worst comes to worst, but nothing on the left hand thread.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Probably can order a LH tap from McMaster-Carr, etc.
Ed
| | | | | Joined: May 2015 Posts: 11,142 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,142 | Are the new ends the same length as the old ones? That may be the cause of them hanging up, needing to screw further into the rod socket.
Take your old tie rod ends and file a flute or two in them similar to what a tap looks like, and use them to chase the threads in the rod. It's probably just rust and gunk that's making the new ends hard to screw in. Use lots of WD40 or other lubricant. Also be sure the clamps are released if the rod sockets are split.
.812 - 18 would be 13/16-18 and I didn't see that size on the McMaster-Carr site.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2011 Posts: 1,459 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,459 | If you have a Fastnal store near you the should be able to source a l.h. tap.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: May 2015 Posts: 11,142 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,142 | I suggested the "tap" made out of the old ends, because the McMaster-Carr left hand taps around the size required were $50-$80 each.  I know a guy can never have too many tools, but holy cow! And for likely a 1-time use.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2017 Posts: 480 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 480 | My local O'Reilly store loans out a thread restorer kit, a bunch of special files to match most threads. I used it to clean up the threads on my drive shaft carrier. Worked great, and while they "sell" it to you when you pick it up, they return your money (or cancel the charge card) when you return it. Might be the easiest way to solve your problem.
Tim
| | | | | Joined: May 2015 Posts: 11,142 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,142 | Another way to chase the threads is to find a smaller diameter tap with the same thread pitch and use that. The files are likely for external threads (that's all I've seen). They would have the teeth that cut along the length of the file, not across it, but I may be wrong on that.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | Thanks for all the replies. I used the old ends as taps but that wasn't the issue. What I determined was the Napa tie rod ends are .002" more diameter than the originals, measured them with a micrometer. Poor quality parts.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Male threads of that size have more than 0.002” tolerance on the OD of the threads. Pitch diameter is difficult to measure without special tools. Pitch diameter is a tighter tolerance and much better data point for determining correct size of male threads, or if it’ll fit a standard size tapped hole.
I wouldn’t assume the new parts are out of tolerance by measuring the OD and finding only a 0.002” discrepancy. 0.002” is half or less the thickness of a standard hair. | | |
