4 members (Gdads51, EchoBravoSierra, HandyAndy, Ol'55), 88 guests, and 2 robots.
Topics128,037
Posts1,055,576
#1318841 07/22/2019 7:39 PM
Hi Y'all, Can you give me the float setting on the Carter WA-1 #504
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
Carter 504S was listed for '41-'48 Olds 238 engine. Photos of the 1950 revision data sheet, below. The float setting is 1/2" from gasket surface to top of the float seam with needle seated. Hopefully the image in the lower right of the first photo has enough resolution to illustrate that. Not sure why the attachment manager flipped them on their sides. If you copy the photos to your desktop, you should be able to zoom in.
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
