| | | Forums66 Topics128,167 Posts1,057,017 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2019 Posts: 40 'Bolter | | 'Bolter Joined: Feb 2019 Posts: 40 | Anybody have a part number/source for hub oil seals for a 48 3/4 ton pick up. It has Eaton floating axles and an HO52 carrier. I found a good Tech tip on this rear end with part numbers for a number of parts but not for the oil seal.
| | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | Your old seal should have the p/n stamped/printed on it...just take it to NAPA and have them order it if it's not on the shelf. Mike B  | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Joel1948, welcome, I come up with National 2081, hope that helps. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Hy Joel1948, welcome, I come up with National 2081, hope that helps. That's the same one I show. It fits practically all 3/4 & I ton GM trucks plum into the 90's. Any parts store should have it. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | | | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | The 2081 seals are also on ebay. I just got two awile back and cheper than anywhere local. | | | | | Joined: Feb 2019 Posts: 40 'Bolter | | 'Bolter Joined: Feb 2019 Posts: 40 | Thanks for all the reply's. Meanwhile, I'm going through boxes and drawers after not working on my truck for 10+ years and ran across a seal in a box and it is a 2081. No doubt it's for my truck! Why I have one and not two or maybe I replaced one and not the other? and if so which one? I better buy another and replace both. Thanks again for your help. | | |
