1 members (CuzzFuzz),
83
Mod | | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2019 Posts: 53 | So I’m looking for some front spindles for my 1/2 ton and not coming up with much. What is the differences between them and the bigger sizes? I’m sure it’s gotta be bearing sizes and just overall size differences? I thought I remembered reading somewhere that you could use 47-5? And the only differences were the 4 bolt hole diameters were larger I believe?
44 Canadian chevy 1/2 ton
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The lower two bolts went from 7/16” to 1/2” when Bendix brakes came in, in 1951. Other than that they are the same. That would be 1951-59.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2019 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2019 Posts: 53 |
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It looks like :
46-50 are the same and 51-59 are the same | | | | | Joined: Jan 2019 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2019 Posts: 53 | Ok thanks. Looks like it just opened up more possibilities for me!
