1 members (Forty9), 66 guests, and 1 robot.
Topics128,055
Posts1,055,782
I swapped out the stock steering box for a CPP power steering unit. The 283 has the front motor mounts, so I am having a difficult time finding a place to mount the power steering pump. This motor does have later heads with the mounting holes. Anyone else ran into this issue?
Thanks.
Several aftermarket suppliers have a bracket kit which incorporates the front mount with the pump bracket. Truck Shop and Brothers have them, probably others.
Fred
Here's my 350 sbc set up. I believe I got my brackets from Alan Grove Products.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Sir Searchalot
Sir Searchalot
Depending on long or short water pump. See pic.
Lots of used 283/327 pump brackets on Ebay.
Do they mount behind the motor mounts? Can't tell from the pictures, but thanks for sharing them!
Sir Searchalot
Sir Searchalot
Got pic off of the web. If you search you will find the info/pix you need.
Ordered them up from Alan Grove Products. He has just about every bracket you could need. This guy knows his brackets! He was a big help in figuring out what pulleys to use as well. Thanks for pointing me in the right direction.
