2 members (dt235sd, Peggy M), 76 guests, and 2 robots.
Topics128,130
Posts1,056,713
Members48,454
#1317553 07/13/2019 2:03 AM
Vintage Truck & Tractor
61 Chevy C20 with 235.. got it out of ther. Dang sure took me alot longer than 45 minutes. Anyway I have a question about connecting rod measurements. The old bari g shells had a stamp on the back side 001 along with some other letters. I assume that means they were .001 oversize . Furthermore, I measured my crank pins. They all ran in the range on 3.308 to 3.309. Spec in the book is 3.311 -3.312. I plastigauged the old bearings clearance and I got .004 to .005. So with that information, what size bearings should I order ? Would the .001 be the size or should I go .002
Current project; 1961 C20, 235 I6
If you can find .002" undersize bearings, use them (they're about as scarce as honest politicians). Be absolutely sure the crankshaft journals are round, and not tapered from one end to the other. It's not uncommon to find a journal egg-shaped or tapered, as well as worn undersize. A .001 or .002 under bearing MUST be used against a round, but undersized shaft only- - - - -no tight spots. If you've got the pistons and rods out of the engine, torque up the rods without bearings in them and measure the inside diameter of the big ends with an inside micrometer- - - -even an electronic caliper won't be accurate enough. They should be round, and measure between 2.4367"-2.4372".
It's hard to believe but its darn hard to find someone to grind a crankshaft in Mt. So I ordered a crankshaft kit with mains and rod bearings. It actually amounts to about the same money.. I also need a camshaft. How about this " Sealed Power CA 251". Anybody have any recomendations.
Elgin Industries. Check out part number E-293S. It is there "Corvette " grind cam. Got very good reviews. Worth checking into.
1950 Chevy 3100
Where-abouts in MT? Great Falls has a couple places.
Chris
Too many to work on
4 bolts, 2 square bodies, 4 GMT400s...and those are the keepers
I am in Miles City. I solved the problem, I bought a crank kit.
Crusing in the Passing Lane
Worn Camshaft bearings will allow low oil pressure, need to be shop installed.
Ed
