0 members (),
116
Mod | | | Forums66 Topics128,105 Posts1,056,541 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2017 Posts: 83 Vintage Truck & Tractor | | Vintage Truck & Tractor Joined: Feb 2017 Posts: 83 | 61 Chevy C20 with 235.. got it out of ther. Dang sure took me alot longer than 45 minutes. Anyway I have a question about connecting rod measurements. The old bari g shells had a stamp on the back side 001 along with some other letters. I assume that means they were .001 oversize . Furthermore, I measured my crank pins. They all ran in the range on 3.308 to 3.309. Spec in the book is 3.311 -3.312. I plastigauged the old bearings clearance and I got .004 to .005. So with that information, what size bearings should I order ? Would the .001 be the size or should I go .002
Current project; 1961 C20, 235 I6
| | | | | Joined: Feb 2004 Posts: 29,835 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,835 | If you can find .002" undersize bearings, use them (they're about as scarce as honest politicians). Be absolutely sure the crankshaft journals are round, and not tapered from one end to the other. It's not uncommon to find a journal egg-shaped or tapered, as well as worn undersize. A .001 or .002 under bearing MUST be used against a round, but undersized shaft only- - - - -no tight spots. If you've got the pistons and rods out of the engine, torque up the rods without bearings in them and measure the inside diameter of the big ends with an inside micrometer- - - -even an electronic caliper won't be accurate enough. They should be round, and measure between 2.4367"-2.4372". Jerry
| | | | | Joined: Feb 2017 Posts: 83 Vintage Truck & Tractor | | Vintage Truck & Tractor Joined: Feb 2017 Posts: 83 | It's hard to believe but its darn hard to find someone to grind a crankshaft in Mt. So I ordered a crankshaft kit with mains and rod bearings. It actually amounts to about the same money.. I also need a camshaft. How about this " Sealed Power CA 251". Anybody have any recomendations.
| | | | | Joined: Aug 2017 Posts: 671 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 671 | Elgin Industries. Check out part number E-293S. It is there "Corvette " grind cam. Got very good reviews. Worth checking into.
1950 Chevy 3100
| | | | | Joined: Jul 2019 Posts: 24 New Guy | | New Guy Joined: Jul 2019 Posts: 24 | It's hard to believe but its darn hard to find someone to grind a crankshaft in Mt. Where-abouts in MT? Great Falls has a couple places.
Chris
Too many to work on 4 bolts, 2 square bodies, 4 GMT400s...and those are the keepers
| | | | | Joined: Feb 2017 Posts: 83 Vintage Truck & Tractor | | Vintage Truck & Tractor Joined: Feb 2017 Posts: 83 | I am in Miles City. I solved the problem, I bought a crank kit.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Worn Camshaft bearings will allow low oil pressure, need to be shop installed.
Ed
