3 members (Shaffer's1950, DannyW, Otto Skorzeny), 126 guests, and 2 robots.
Topics128,080
Posts1,056,291
Members48,441
#1317417 07/11/2019 9:45 PM
[b][/b]
I believe the spring and the large strange shaped washer go below the cab, underneath. To secure the the parking brake arm to the transmission. But not sure?
Also i believe that the flat shaped part with what appears to be rod grasp go on the parking brake grip handle but not certain?
24601
What year truck? Which transmission??
The flat thingy looks like a wheel cylinder adjustment hole cover (goes in the backing plate).
Did you take it apart??
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
I did take it apart
8 years ago unfortunately
I have 1950 GMC 1 TONNE PICK UP with a 4 speed manual transmission
Reason i associated the parts with the parking brake assembly is that i had the assembly chromed
The spring and dome washer are from shifter stick on the 4 speed, not parking brake.
•1952 Chevrolet 3800 pickup
---All pictures---
Moderated by  Dusty53
