7 members (fonz8261, Shaffer's1950, tclederman, Hotrod Lincoln, Bill Hanlon, Charles in CA, 49choptop), 74 guests, and 3 robots.
Topics128,087
Posts1,056,376
Members48,442
#1317022 07/08/2019 8:55 PM
Hi guys,
Does anyone have any new studs for 42 chev. 1 1/2 ton truck.
2 13/16 long
9/16 bolt size fine
Picture of specs attached..
Thanks in advance. Jack
Good luck with getting a bolt, Jack
However, a personal request such as this belongs in the Swap Meet?
One reason for this is because posts in non-Swap-Meet fora/forums do not get deleted.
3B Offline
Hy jack02, try looking up Dorman part number 610-180 and see if that fills the bill
no it didn't.
thanks
3B Offline
Hy jack02, okay some more research has yielded another Dorman part number 610-303.1, I realize it is longer than required, but you can always cut them down, hope that helps
Crusing in the Passing Lane
What size are the holes in your wheels? If 5/8", there is a selection of them. Spline ID in the hub is important, as well as length. I found some at a GM dealer, they had no clue what they fit, searched by dimension in their paperwork, had to order 1 ea. as samples 'til I found one that fit.
Ed
