| | | Forums66 Topics128,042 Posts1,055,501 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 13 New Guy | | New Guy Joined: Feb 2006 Posts: 13 | any info on using MII parts for front clip and keeping the old fame. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Do a google search, there are tons of vendors selling brand new kits to put the MII steering under an AD truck. Mike B  | | | | | Joined: Nov 2018 Posts: 122 'Bolter | | 'Bolter Joined: Nov 2018 Posts: 122 | Jeeper, I used a Fat Man Fabrication, Stage 3, Kit on my 51-3100. The Stage 3 kit uses adjustable coilover shocks. Quality parts, excellent, easy to follow instructions and it worked out very well for me. Check them out at www.fatmanfab.com. Good luck!
Charlie
'51 3100 5-Window (Restomod in progress)
| | | | | Joined: Aug 2018 Posts: 219 Moderator, Great Lakes Bolters | | Moderator, Great Lakes Bolters Joined: Aug 2018 Posts: 219 | Speedway Motors sells a bolt-in Mustang II crossmember. https://www.speedwaymotors.com/Bolt-In-1947-54-Chevy-Pickup-Mustang-II-Crossmember,50961.html
--Tom H.
| | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | I used an actual Ford OEM wrecking yard MII on my original frame. Makes life easy for maintenance and parts replacement.
1951 Chevy Panel Truck
