3 members (rfs56trk, Chip O, Hotrod Lincoln), 98 guests, and 8 robots.
Topics128,077
Posts1,056,013
Members48,433
#131730 07/16/2004 1:29 AM
7
7 Offline
I have been reading thru some of the archives for the gas tank and I just don't know what to do...so I thought I would open it up for suggestions.
I am sorry if my brainstorming is annoying any of you. wink
Anyway....I want to go ahead and move the gas tank to the back and patch/blend the current filler area on the cab.
The question is what should I do with the filler.
Has any put it going straight out to the license plate area? I don't want to be anywhere obvious...I am looking for a clean smooth look for the truck.
I doubt I will be putting on any emblems on her either.
*sigh* open for ideas! smile
Thanks for all your patience. smile
Stella
1970 Monte Carlo 355
1987 Camaro IROC-Z 305 TPI
1955 Chevrolet Second Series
GET-R-DONE
#131731 07/16/2004 6:04 PM
You can:
1. run it out the back but worry about tailgate clearance.
2. build it into the floor of the box but could be a pita when stuff is loaded in the back.
3. run the filler out the side. I've seen nice grafts of filler openings with doors mounted in the rear portion of the rear fender.
#131732 07/16/2004 7:10 PM
You can see what the PO did with mine -- NICE job! -- Click Here
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
