0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#1317080 07/09/2019 2:01 PM
Vintage Truck & Tractor
61 chevy c20. Can I remove the oil pan and check rod bearing clearances inframe
Current project; 1961 C20, 235 I6
Probably. You might want to check the distance between the front of the pan and the crossmember to see if it might be necessary to disconnect the motor mounts and jack the engine up a little. Since the 54-62 engines use replaceable precision bearings, just install a new set of rod bearings while you're in there. It's cheap insurance!
I thought I would push the pistons out and re ring it as well ,while the head is at the shop.
Pulled the entire engine on my ‘62 C-10 in 45 minutes. It’s going to be a tight squeeze to try to work around the crossmember. As Jerry said you will need to remove the front motor mount and Jack the engine up a bit.🛠
Going to pull ft he engine, hopefully tomorrow. If not then friday.. thanks for the advice guys.
Great plan, Dave! It will be so much easier to do what you are trying to do, plus it will give you a chance to clean up the engine bay while the engine is out.
