Hello All
Converting my '51 3100 to a 12 volt system. In the process of installing a '57 261 engine and recently aquired a NOS Delco Alternator conversion kit.
My question is the Ignition resistance routing.
The #1 terminal on the alternator has a connection for a "calibrated wire" terminating at the (+) terminal on the ignition coil. I assume that this wire is also known
as the resistance wire. Does hooking this wire up as shown in the instuctions eliminate the need for the cermanic firewall resistor?
Also I have the "R" terminal on the push starter solenoid, would I also run a resistance wire to the coil? My coil states to use external resitance source.
Bud
Wiring Instructions
