6 members (Hotrod Lincoln, moparguy, Ponchogl, klhansen, Bill Hanlon, 1 invisible), 65 guests, and 2 robots.
Topics128,023
Posts1,055,370
Members48,420
#131665 10/22/2002 10:29 AM
A while ago there was a thread concerning putting a 500 caddy motor in an AD. Anyone got an update?
Send David Hicks home - now!
"Better to be wrong and kill no one then right with mass graves" Albert Camus
#131666 10/23/2002 1:21 AM
Junior Member
Junior Member
Quote
Hey,
I'm not sure about any posts on this site but check my post over at the Chevy Duty website. someone replied to my post about big blocks. He said he put a Caddy 500 in a '51 AD.
#131667 10/23/2002 7:29 PM
sounds iteresting
I am thinking about
puting a hipower 427 in my 53 it would be close to the same size as a 500 caddy
I met a guy that always used older caddy engines
in his chevy pickup he said thay were much cheeper the standerd chevy engines (I dont think thay would be any cheeper to rebuild)but mabe the used ones are cheeper
personly I would wrather use a 502 chevy
much beter to get parts for
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
1969 Chevy 3/4 ton 4wd
http://www.stovebolt.com/gallery/dahlin_luke_1969.html]1969 Chevy 3/4 ton 4x4
#131668 10/23/2002 9:48 PM
smile howziit guys!
i'm out in the middle of the pacific ocean, so i need to use what's readily available.
the 500 caddy is not too easy to find, and more expensive to rebuild/modify.
SBC's are plentiful, 396/427 BBC's not too easy to find, but the 454 always seem to pop up, at a good price.
good price, readily available parts, easily adaptable, power to spare...
back in my younger days, i'd probably go Caddy 500.
nowadays, i like BIG belly-buttons! grin grin grin
Myron
1956 chevy 3100 stepside, Pro-Street stance, mild 454 BBC/350/9"/13" M/T'S, daily driver, aka THE PINK LADY
1957 Bel-Air coupe, 500 HP blown sbc in progress, aka LANI
#131669 10/24/2002 12:49 AM
Here's a Link to the original thread. Anyone heard from any of these guys lately? Thanks for your link evers310.
#131670 10/24/2002 1:50 AM
Junior Member
Junior Member
Quote
Sorry, I forgot to put the link in my post:
http://iserver.chevyduty.com/cgi-bi...ad_count&om=809&forum=DCForumID3
#131671 10/24/2002 8:56 PM
I have thought about doing it myself. With all that extra power would have to do some reinforcing of the frame of which didnt want to get into. Here is a picture of one from anther site it looks good! www.hotrodders.com/vehicles/55.html
grin
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces
2000 GMC Serria 1500 SL 4x4
#131672 10/25/2002 2:48 AM
Z
Z Offline
im putting one in my 64.
#131673 10/25/2002 3:26 AM
Any chance of a progress report etc. If you are taking photos etc we can help you post them if you dont have a web site. Seems to be a bit of interest in this swap. Hey Solowookie saw you over at the HotRodders forum asking about this too. Any new info. Did you see that VW with the caddy motor insane stuff.
#131674 10/27/2002 4:38 PM
Caddy bigblock advantages:
1. MASSIVE torque-400-500 ft-lbs
2. packaging-not much bigger than a smallblock
3. weight-about the same as a smallblock.
4. If you don't need to modify engine, you should be able to find good runner CHEAP.
Just my $.02.
Regards,
Wannabe smile
"Don't expect anything and you'll never be disappointed"
#131675 10/29/2002 4:09 PM
The caddy motors are torque monsters. The specs that Wannabe quoted are for STOCK engines. I think that they are lower-RPM motors, stock redline of 5,200 RPM or so. You don't have to revv them up like a SBC, just gear them to take advantage of torque, and to keep the cruising revvs down. Similar to a 455 Pontiac.
When comparing the performance of two different motors, you have to look at the bore and stroke, not just the CID. A Chevy 427 has a higher powerband than a Caddy or Poncho, but at the expense of some low-end torque due to shorter stroke.
Rough rule of thumb:
Bore bigger than stroke: Oversquare- High RPM IE Chevy 350 4" bore, 3.48" stroke
Bore about equal to stroke: Square- midrange/high RPM
Poncho 428 4.12" bore, 4" stroke
Bore less than stroke: Undersquare- Low RPM Torque monster.
Poncho 455 4.151 bore, 4.21 stroke
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#131676 11/05/2002 3:01 AM
Here's some links and another from hot rod magazine re 500 build ups.
