0 members (), 142 guests, and 2 robots.
Topics128,132
Posts1,056,730
Members48,454
#1316677 07/05/2019 11:03 PM
[img]http://bodypart[/img]
What year do you think they are for?
•1952 Chevrolet 3800 pickup
---All pictures---
I figured it out...
There stiffeners for the front inside fenders
I wanted to delete post but not sure how
You can’t delete once someone posts replies.
Fox Offline
You’re right gas dude. Those are aprons for a 47-53 GMC front end. They bolt to the front of the inner fenders and then the protruding vertical tab bolts to the outer fender and grill. There is also a center piece that bolts to the core support. Your pieces bolt to this as well.
Here are some photos: only one actually shows the pieces installed (black truck) while the one other shows the truck in primer and you can see exactly where those pieces would drop into place behind the front bumper pan.
https://photos.app.goo.gl/8ewMCybXiWmKCFNn8
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Offline
Offline
No need to delete. The info stays here for the next guy with the same question!
My 1955 GMC 450 Dump Truck
Elderly Iron
"Performance" is the pursuit of a toy that won't break.
Moderated by  Dusty53
