6 members (mk72, SNOYL, cmayna, JW51, 78buckshot, Phak1), 56 guests, and 6 robots.
Topics128,012
Posts1,055,320
Members48,419
#131663 11/16/2003 3:48 PM
Junior Member
Junior Member
I have a Chevy small block in my truck. I have placed the oil sensor at the top of the engine close to the distributor.
There are two other threaded "holes" in the engine that may require plugs. One is a few inches below the oil dip stick hole and the other is above the oil filter. I believe the one above the oil filter is an alternate oil sensor hole.
Do I have to plug both these holes? If so, what size threads will the plugs require? The plugs I have are 1/4 inch but I am nit certain they are NPT. I thought I read somewhere they use NPT threads.
Richie West
#131664 11/16/2003 5:05 PM
Meredith: Your correct about right above oil filter (oil sender) my 88 GMC is there. Didn't know about 3rd one. Anyway pretty sure that is 1/4 Nat. Pipe Thread. If there is holes yes plug them. popcorn The Truth is Out There. (The one next to dipstick isn't a heat sensor alternate is it)
