4 members (Hotrod Lincoln, 55shaker, rfs56trk, Wally / Montana), 99 guests, and 3 robots.
Topics128,065
Posts1,055,868
Members48,428
I ended up getting the factory style V8 front motor mounts for the 57 farm truck. I was piddling around with it yesterday and noticed the front motor bracket conflicts with the harmonic balancer. The harmonic balancer I have measures 8" diameter that came on my 350. What size should I be looking for?
Both of my TF 350 V8's have ~7" Balancer...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks mike. Mine measures 8” and still seems to have a ways to go. Maybe the aftermarket bracket is a little bigger? Maybe it’s closer than I think?? πŸ˜€
The repro setup is exactly like the original, I have them both...
Looking at my balancer's it looks like the drivers side would have enough room for your 8" balancer, but the passenger side would be close.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Ok thanks Mike. I’ll prob order a $50 6.75” off summit this morning so I can hopefully work on it this weekend.
Riding in the Passing Lane
If you are using the 2 piece set with the bird legs, you can cut a little chunk out of the brackets. If you are using the horseshoe bracket I'm not sure of.
George
1972 Chevy c10 Cheyenne Super
I am using my he bird legs but it was going to take a big hunk. I ordered a 6.75” balancer. May still need to trim but maybe not near as much.
