| | | Forums66 Topics128,042 Posts1,055,518 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 97 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 97 | Not sure if this is the best place to start this thread but my question is: Does anyone have advice or suggestions for installing the rubber windshield gasket for a 46 Chevy? Mine is original and not new, if that matters.
thanks, lane in mt. hermon, louisiana
sweetpealane
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1946 Chevrolet car or truck? (car/truck might not matter) Have you read/studied the Shop Manual?Someone with first-hand experience will respond. | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Not sure if this is the best place to start this thread but my question is: Does anyone have advice or suggestions for installing the rubber windshield gasket for a 46 Chevy? Mine is original and not new, if that matters.
thanks, lane in mt. hermon, louisiana If you buy your new gasket from Steele Rubber the installation will be easy. I understand from others that used other products from other vendors had more difficulties. Use soapy water to lubricate the gasket channel as you work your way around the window and frame. I used the cheap Harbor Freight plastic tool set to gently coax the gasket into place. With the glass and frame on a work bench it took less than 45 minutes to complete the task by my self. | | | | | Joined: Oct 2013 Posts: 97 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 97 | thanks to you both ........... my gasket came from our favorite chevy vender on stovebolt but my old frame that I cleaned up and repainted was very tight around the 2 bends on one side and the gasket simply would not go thru' the more narrow spot ............ my problem may be the frame ............ thanks again lane
sweetpealane
