7 members (Donf, Gdads51, 55shaker, TUTS 59, Forty9, Donsz, Gray_Ghost),
126
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,056 Posts1,055,799 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 43 | I ended up getting the factory style V8 front motor mounts for the 57 farm truck. I was piddling around with it yesterday and noticed the front motor bracket conflicts with the harmonic balancer. The harmonic balancer I have measures 8" diameter that came on my 350. What size should I be looking for? Thanks | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Both of my TF 350 V8's have ~7" Balancer... Mike B  | | | | | Joined: May 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 43 | Thanks mike. Mine measures 8β and still seems to have a ways to go. Maybe the aftermarket bracket is a little bigger? Maybe itβs closer than I think?? π | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | The repro setup is exactly like the original, I have them both... Looking at my balancer's it looks like the drivers side would have enough room for your 8" balancer, but the passenger side would be close. Mike B  | | | | | Joined: May 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 43 | Ok thanks Mike. Iβll prob order a $50 6.75β off summit this morning so I can hopefully work on it this weekend. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you are using the 2 piece set with the bird legs, you can cut a little chunk out of the brackets. If you are using the horseshoe bracket I'm not sure of. George
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 43 | I am using my he bird legs but it was going to take a big hunk. I ordered a 6.75β balancer. May still need to trim but maybe not near as much. | | |
