3 members (TUTS 59, 1955 1 Series, dt235sd), 97 guests, and 2 robots.
Topics128,141
Posts1,056,488
Members48,441
I was doing some reading up on Smithy's and I have just one concern. First, I understand that the note these mufflers put out is much admired, but it appears that you can only find them with a 2" inlet. With a Fenton dual intake/header setup, will this prove to be restrictive on my engine? Will I be better served to go with a universel fit muffler like Dynomax or Magnaflow? I have a 261 and it will have the Howard's M4F cam from Patrick's in it, if that makes a difference. I am close to having it ready to go in my truck. Thanks for the input.
Whad you do?!?
Shane
1953 Chevrolet 3600
Part of their distinctive sound comes from the 2" diameter, tone changes w/diff diameters. I don't think 2-2 inch pipes will be much restriction for that size engine. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
I love my dual Smithy's. With the pipes out of the rear they are almost too quiet. I got the longest ones there are.
54 3100 with 235
62 flatbed dump C60 with 261
I have them on my 52 with a 235, fenton headers, m-4 cam, etc,, I love em, some have said that they sound real good.....Fred
Redryder pix
My Hotrod
Sound advice...I'm inclined to go the Smitty route...in fact, I WILL go the Smitty route. One more question, is an 'h' pipe necessary to tune the exhaust or not? I was thinking of running the two pipes from the headers side-by-side into two Smittys or would it be better to collect into one main pipe and then into one Smitty. Seems like the second would be more restrictive but eliminate the tuning issue if there is one. Thanks. Any recommendations on who sells the cheapest Smittys?
Whad you do?!?
Shane
1953 Chevrolet 3600
Fred,
What's yer 20?
Whad you do?!?
Shane
1953 Chevrolet 3600
