1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2017 Posts: 177 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 177 | I need to get some new wheels. But I don't know what backspacing I need or how wide I should get.
1950 Chevy 3100. Factory ride height. Straight axle. Added disc brakes. Instructions said the disc kit would add 1/2 or 3/4 of an inch of each side. I want to keep with 15 inch. Disc kit changed lug pattern to 5x4.75. I also have power steering using GM box on frame.
What have you guys used? What backspacing and wheel width do you guys recommend.
Matt
| | | | | Joined: Dec 2018 Posts: 473 Shop Shark | | Shop Shark Joined: Dec 2018 Posts: 473 | The internet has tons of articles and tech advice on the subject of wheel design including offsets and backspacing. Take some time and read up on how to achieve your desired results. | | | | | Joined: Jul 2000 Posts: 2,187 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,187 | My wheels are 15" steel with 5x4.75 bolt pattern. Width is 6" or 7". Backspacing is 4".
Disk brakes on front. Camaro rear axle.
Works fine.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jun 2017 Posts: 177 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 177 | My searches haven't come up with as much as I thought they would.
I'm still trying to figure out wheel specs. Offset, backspacing, width and what tires to use.
For the most part I'm finding that factory wheels had a 3.5 inch backspacing. But if they were narrower, wouldn't that mean I need a high backspace to even it out?
Another search, someone was said that you shouldn't go more than 4.5.
I'm just trying to not order something that won't work. I found a couple of posts that talked about using a piece of metal on the rotor and a threaded rod to check for clearances id like to try. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jul 2000 Posts: 2,187 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,187 | Offset is the distance from the center of the wheel to the mounting surface. Back spacing or rear spacing is the distance from the rear of the wheel to the mounting surface.
Offset can be negative or positive.
