1 members (53 green 1- ton), 110 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
Now I have a pair of original tail lights for my 37,not sure if I am going to keep the two bulbs or got with one 1157 in each light. I need to order gaskets and conduit and might be winter before I can get to them since we had nothing but rain I need to do a bunch of other work around the house.
That lens was designed to have two bulbs, one for the running light to shine through the top and the stop light to be lined up with the bulls-eye on the bottom. Putting one bulb (1157) in the center, upper or lower position will diminish the capacity of the other areas and not be as effective in my opinion.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Jeff,
If your car is 6 volt you need a 1154 bulb. 12 volt use a 1157 bulb.
You do know the bulbs in your current light are single Filament. If you change to a dual Filament 1154/1157 you will have to change the socket accordingly..
Harold
Harold
A little more expensive. But worth it for more light output and less draw. This just one example Amazon has a whole selection.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
