8 members (Wickedbass, MNSmith, 2-Ton, JW51, Maybellene, Hotrod Lincoln, 2 invisible),
88
Mod | | | Forums66 Topics128,042 Posts1,055,595 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2018 Posts: 473 Shop Shark | | Shop Shark Joined: Dec 2018 Posts: 473 | Why is it this manual doesn't include any factory details on the 58 or 59 years?  | | | | | Joined: Dec 2018 Posts: 473 Shop Shark | | Shop Shark Joined: Dec 2018 Posts: 473 | Were there supplemental manuals required to cover these years? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the FAM around now is a reproduction of the assembly sheets GM issued to the line in 1955, there were updates ["running changes"] but none of those have been found/repro'd - notice the dates on various pages, some from before 55, none after .... the "manual" is labeled 55-59 by the modern re-producer, there is nothing specific to the later TF series
| | | | | Joined: Dec 2018 Posts: 473 Shop Shark | | Shop Shark Joined: Dec 2018 Posts: 473 | So there is not any factory reference material circulating out here for TF owners...really.  | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Why is it this manual doesn't include any factory details on the 58 or 59 years?  So there is not any factory reference material circulating out here for TF owners...really.  Wikipedia: "The Task Force Series ran from late 1955 (second series) through 1959." You are most likely referring to late-years Task Force owners? There is a similar, but opposite, situation for 1947-1953 Chevrolet Advance-Design Series owners. The "47-55st FAM? is actually 1954/55st. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | "Task Force" = all the 55.2 thru 59 models .... very little difference in the years 55.2-57 and the 58-9 .... only the front fenders, hood, grill, and the late frame is a couple inches longer in front, otherwise cab and bed, interior and mechanics all the same as shown in the "55-59" FAM
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | What the manual is missing for 58-59 can be answered by Bill and other members. Not to worry. As said, many systems/parts/part numbers are the same 55.2-59. Bill is the Guru on TF. Absolutely.........and he knows apples from oranges. (Hi Bill, how you doin? Lost your info on my last FBI raid)
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2018 Posts: 473 Shop Shark | | Shop Shark Joined: Dec 2018 Posts: 473 | Bill, I have found nothing regarding the 58-59 fleetside bed design within the FAM.
| | | | | Joined: May 2015 Posts: 11,024 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,024 | The 47-54 FAM doesn't have squat on the bed (either pickup or larger). But, Hey! doesn't everyone know how to assemble a bed?
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | OK. having had both long and short fleet beds I should've known to add those to the list .... but there's really nothing about the fleet beds that should need any explanation other than the bed wood,, and this page shows the number and size of boards required .... also there's dimensional info in the 58 resto pakas said, the FAM was a find of a pile of loose sheets by a truck nut in about the 70's [Seth Doulton, the Golden State PU parts founder, note the copyright], no other line instruction sheets have surfaced and you might not be aware there was a major fire at a GM plant where most archived info was kept and so prolly what we have now for any assembly info of any year is all there will ever be Bill | | | | | Joined: Dec 2018 Posts: 473 Shop Shark | | Shop Shark Joined: Dec 2018 Posts: 473 | And so the world turns...thanks as always for the education in the Bolt world. | | |
