1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 55 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 55 | Hi All,
Anyone happen to know the length on the pushrod cover bolts? I believe they are 1/4-20 thread, but not sure if the length is 3/8, or 1/2.
Thanks!
LOS ANGELES, CA
48 FLEETLINE AERO, 50 CANOPY EXPRESS
52 SUBURBAN, 57 BIG WINDOW Pickup, 64 Malibu CV
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Year, make, model/size/type engine? For a 216/235/261 Chevrolet engine: Most likely you will need a 1/4 x 20 stove bolt screw? StoveboltFor some people, any 1/4 x 20 bolt, with any style lock washer will do | | | | | Joined: Mar 2014 Posts: 4,498 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,498 | Hi Sergio, I used 3/8 inch length and a flat washer (about 3/4" diameter as I recall). Unless you seal it very well, this cover will leak at the lower rear and mimic a rear main seal leak. Anytime I have to remove one, I straighten the area around the bolt holes really well. The flat washer keeps the bolt head from deforming the cover. Good luck.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
