0 members (), 202 guests, and 6 robots.
Topics128,101
Posts1,056,181
Members48,436
#1315505 06/24/2019 6:51 AM
Hi All,
Anyone happen to know the length on the pushrod cover bolts? I believe they are 1/4-20 thread, but not sure if the length is 3/8, or 1/2.
Thanks!
LOS ANGELES, CA
48 FLEETLINE AERO, 50 CANOPY EXPRESS
52 SUBURBAN, 57 BIG WINDOW Pickup, 64 Malibu CV
Year, make, model/size/type engine?
For a 216/235/261 Chevrolet engine:
Most likely you will need a 1/4 x 20 stove bolt screw?
Stovebolt
For some people, any 1/4 x 20 bolt, with any style lock washer will do
Moderator, Electrical Bay
Hi Sergio, I used 3/8 inch length and a flat washer (about 3/4" diameter as I recall). Unless you seal it very well, this cover will leak at the lower rear and mimic a rear main seal leak. Anytime I have to remove one, I straighten the area around the bolt holes really well. The flat washer keeps the bolt head from deforming the cover. Good luck.
~ Jon
