3 members (Gdads51, 1955 1 Series, cmayna), 113 guests, and 2 robots.
Topics128,193
Posts1,057,249
Members48,466
#131546 07/14/2004 2:18 AM
7
7 Offline
Seems like it could be the way to go....won't have to cut up a frame and I can put it back to original if I want....
Can someone edumacate me? Sorry for all these questions..I just want to be happy with my decision in the end and wish I did something else, you know...
Stella
1970 Monte Carlo 355
1987 Camaro IROC-Z 305 TPI
1955 Chevrolet Second Series
GET-R-DONE
Use the search feature, you'll find a load of stuff on IFS. Don't rule out the old straight axle either. Have fun
Rollin' Hard
1946 Chevy 1/2 ton
1959 Phord 1/2 ton
2001 Chevy 1/2 ton
I think the MII is the way to go,however it would be quite a job to put your truck back to original.On my 55 2nd series I had to cut out the front crossmember,and box the frame.I had to use different motor mounts because the originals were mounted on the front crossmember.It is still a lotr easier than cutting the frame and sub framing.The one I used was from TCI.Mainly read and follow the instructions.
7
7 Offline
darn...I think the bad thing about woman being into cars...or at least for me..I can't seem to make up my mind.
I have come to realize that I have no idea how my truck would drive 'stock' so I shouldn't cut myself short and change it when I very well could have liked it... So I am going to get up with my AACA buddies to see if they can hook me up with a stock Task Force truck to go for a ride. I owe it to my truck and myself to see what I have before I start changing it.
I know..I know...I can't make up my mind....sue me. wink grin
Stella
GET-R-DONE
I think you're being very smart.
wink
You just may like it as is and save yourself a lot of work and time ... or you may hate it and then you'll know for sure that the extra work and time is worth it.
I bought my truck with the Musatng II IFS already in it, so I can't compare, but I sure like it as it is. It also has 11" front disc brakes (drums in the rear) and a double-bay master cylinder, so it stops just fine.
I thought I was gonna want power steering, but after driving it with manual steering, I've decided it isn't necessary at all.
Have fun!
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
Whatever turns you on.Its your truck.Good luck
