Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (TooMany2count), 49 guests, and 1 robot.
Topics128,009
Posts1,055,291
Members48,419
Page 2 of 2 1 2
1 Offline
I installed it right where the mechanical pump is, with the intention of moving it closer to the tank once I tested it to work as needed. I didn't do this from the beginning, as it involved cutting the existing fuel line and I didn't want to do that in the unlikely event I wasn't happy with the electric pump. This leads me to another question, still having the mechanical fuel pump installed but not having any fuel running through it, do I risk damaging it as it's running dry?
Originally Posted by DennisM
Running with no cap is about as vented as you can get. Where did you install the pump?
Dennis
They do push better than pull but I did the same on an old Dodge D50 pickup once. Mounted by the engine to get me home. It kept working fine so never moved to towards the tank. Maybe someone else can advise if it harms the original. I don't know. Hope you find the problem. I'm out of spit on this one.
Dennis
40 Chevy 1/2 ton
Page 2 of 2 1 2
