2 members (dt235sd, carbking), 103 guests, and 2 robots.
Topics128,266
Posts1,058,368
Members48,485
#131513 03/26/2005 4:41 PM
I heard somewhere that you can take a 194 head and put it on a 250 or 292 to increase compression. I'm sure there has to be other things done as well to get the desired results. Does anybody know any thing about this? Thanks,Mike
#131514 03/26/2005 6:22 PM
Yes that is a good way to increase compression, if you can find one! There were different heads made for the 194, so check the number before you pay for one. I believe the Inliners web site has the part number list you will want. You might want to get a copy of the Power Manual wrote by Leo Santucci, it has a lot of information on the 250 and 292. Mostly racing stuff, but a lot can be used on the street.
The 194 head with 1.60" exhaust valves with mild porting will make a great head for a street 250. Get a mild camshaft to go with it. You should end up with 9.3 or so compression.
You can also get the same or better results with using 307 CI V-8 pistions. These pistions will give about 9.6 or so compression, maybe a bit more or less depending on the condition of your head.
#131515 03/28/2005 8:16 AM
The 307 pistons won't work on the 292. Propane pistons are available. The 'performance pistons' thread in the Engine & Driveline shop has more info. Also...get the Santucci book -- it's your friend.
1954 GMC De Luxe COE
