| | | Forums66 Topics128,095 Posts1,056,072 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 109 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 109 | I am done with all my fit up pulled my tuck all apart now chassis paint? Just regular base coat clear? Por 15? rustoleum ? Powder coating is too expensive for my set budget on this. So what do you all suggest? This is not original. It has a camaro clip four link with 9" | | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | Chassis saver works like por 15 and does not have all the steps involved but it is affected by the uv rays and needs to have a top coat like tremclad or similar | | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | I rattle-can everything. It's inexpensive, easy to touch up, and who's gonna ever see it? Rustoleum is surprisingly tough when it's fully cured - feels almost like powder coat.
1951 Chevy Panel Truck
| | | | | Joined: Jul 2000 Posts: 2,192 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,192 | We used Endura 2 part epoxy paint on the chassis. Really tough... https://www.linkedin.com/company/endura-paint
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | POR and similar urethane types don't have a lot of elasticity. A flexible type finish is best for frames that tend to flex. If the proper steps aren't taken with POR good adhesion may be problematic down the road.
| | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | I second the vote on Rustoleum. Unless you are going for a full restoration with car show quality pain job you can't beat it for price and durability. As miraclepieco said, easy touch up also. | | | | | Joined: Dec 2018 Posts: 2 New Guy | | New Guy Joined: Dec 2018 Posts: 2 | Which product(s), specifically? The Endura product line is long and full of options! Thanks, Sweet47Poppy | | |
