5 members (Bill Hanlon, 51sub, Otto Skorzeny, carbking, Chip O), 73 guests, and 5 robots.
Topics128,181
Posts1,057,189
Members48,465
Hi:
I have two questions if you can help me with the answers:
1- Does the 1/2 ton suspension bolts up to 3/4 ton or is there any dimensional differences? For example does the leaf springs are the same size/length and their differences are in the load ratio only?
2- Besides the wheel base, is there any structural differences between 1/2 ton and 3/4 ton frames? is 3/4 ton thicker, larger…...?
1953 GMC 150: new member
1967 Chevy C20, 4 wheel 8 lug disc, 350 engine with Fitech carb (in progress) , T5
1972 Chevy Nova, 4 door sport sedan in the making smile
1979 Chevy Camaro Z28, 5,3 Vortec and TH350, 4 wheel disc and Hydroboost; Just about becoming summer daily driver
For AD (47-54) trucks, according to the FAM, distance between front spring eyes on the frame are the same on 1/2 and 3/4 ton, but the rear springs are actually longer on the 1/2 ton (~52") than the 3/4 ton (~44"), and according to the GM specs, the 3/4 ton frame is deeper (vertical dimension) and also thicker (3/16" versus 9/64"). The 3/4 ton rear springs are wider (2") than the 1/2 ton rear springs (1-3/4").
In addition to the above. For 48-54 (you didn’t specify year?)
You can easily remove and replace 1/2 ton and 3/4 ton front axles with each other because the springs are the same width and spacing. The 3/4 ton would have stiffer springs, you could also swap front springs between them if desired.
The rear part of the frame (behind cab) is vastly different between 1/2 ton and any larger truck.
1/2 ton kind of flares out wider and wider as the frame goes back.
3/4 ton and larger has parallel frame from the cab back at about 36” outside to outside.
•1952 Chevrolet 3800 pickup
---All pictures---
Thank you very much for the detail. I am sorry, I didn't mention the model and year since it was in my signature, 1953 GMC 3/4 ton. I guess the next question would be if there is a difference between Chevy and GMC frames.
So, if the frame is different behind the cad, the bed panels from 1/2 will not fit 3/4 ton, is this correct?
I have a 3/4 ton than I plan to keep the 8 lug driving gears but I don't mind the 1/2 ton softer ride.
If you're not planning on doing "real truck" stuff you can soften the ride by removing a few leaves from the 3/4 ton springs. That would be a lot simpler than trying to do a swap of major components like complete spring packs, etc. Leave the main leaf in place for mounting purposes, and remove a few of the shorter, stiffer upper leaves. You can also soften the ride somewhat by using thin Teflon strips between the spring leaves to let them slip past each other more easily. Some of the "resto-modded" Cowboy Cadillacs never see a load heavier than an iced-down Yeti cooler on the way to a tailgate party- - - - -heavily padded to avoid putting scratches in the glossy-varnished Mahogany bed wood with chromed hold-down strips.
Crusing in the Passing Lane
And fuel fillers in the middle of the bed, making sure they will never carry anything in the bed.
Ed
