3 members (Paul Mullen, JW51, GrandpasJimmy), 96 guests, and 1 robot.
Topics128,110
Posts1,056,241
Members48,437
#131404 08/21/2002 2:08 AM
in about 2 weeks are so i am going to be getting a 58 3800 to convert to a 4 dr with a long bed my question is where a re the factory seams at on the cabs the one to put the roof on the back.
i also have a 58 3200 i using the cab and bed in the conversion. im also kinda up in the air about the front suspenion should i use a volre or camro?
#131405 08/24/2002 12:29 AM
Arkrider, you might want to edit your post, maybe making the title more specific to your year and model-that way, any of the fellas who have these trucks and have your answer might be able to help you out. Also, do a search on the 'net for "railroad trucks" and "coachbuilders" as several trucks were built as crew cabs for the railroads in the past. You might get some ideas. You might also post for Jolly here on the board-I think he's a railroad "nut."
Hope this helps.
Wannabe smile
"Don't expect anything and you'll never be disappointed"
