9 members (55shaker, 1955 1 Series, BC59, 3800GUY, RaNfLaS, tclederman, Otto Skorzeny, wilbur53, FAST55),
156
0
Mod | | | Forums66 Topics128,104 Posts1,056,201 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 12 Member | | Member Joined: Feb 2001 Posts: 12 | in about 2 weeks are so i am going to be getting a 58 3800 to convert to a 4 dr with a long bed my question is where a re the factory seams at on the cabs the one to put the roof on the back. i also have a 58 3200 i using the cab and bed in the conversion. im also kinda up in the air about the front suspenion should i use a volre or camro? | | | | | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Arkrider, you might want to edit your post, maybe making the title more specific to your year and model-that way, any of the fellas who have these trucks and have your answer might be able to help you out. Also, do a search on the 'net for "railroad trucks" and "coachbuilders" as several trucks were built as crew cabs for the railroads in the past. You might get some ideas. You might also post for Jolly here on the board-I think he's a railroad "nut." Hope this helps. Wannabe
"Don't expect anything and you'll never be disappointed"
