1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 44 'Bolter | | 'Bolter Joined: Apr 2012 Posts: 44 | I have a 1957 261 that I plan on installing in my 51 3100. I would like to use the 57 bellhousing because of the better mounting stance and I dont want to use the spindle leg front engine mounts. I could use the bellhousing from the 51 but would prefer the 57.
I have searched the forums and saw mention of modifying the 51 crossmember or bellhousing but no description as to how it was done.
Thanks for any insight. Bud
There is not a tool made that if you don't try hard enough you can't break! 1952 3100 261 T5 3.08 Gov Locker
| | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | The crossmember you'll need to find is from a 54 or 55 1st. series truck. It has the angled mount pads that fit your 57 bellhousing. Try putting an ad in the "Parts Wanted" forum to see if someone might have one left over from an automatic transmission conversion. The crossmember was hot-riveted in originally, but a replacement can be installed by using tapered punches for hole alignment and reaming the rivet holes for shouldered bolts. That crossmember also reinforces the rear spring mounts, so simply using regular bolts for installation allows too much frame flex. Jerry
