3 members (NH46COE, Hotrod Lincoln, 1 invisible), 111 guests, and 8 robots.
Topics128,077
Posts1,056,031
Members48,433
#131340 01/14/2003 4:17 AM
I have a question. I was wondering if anyone has put one piece window glass in the doors of a 53 or any other year truck that came with a vent window. I have my truck chopped already and want to put one piece glass but don't want to put 48 doors on it. Has anyone done this? Is it Possible? Thanks for the input.
Mac
#131341 01/14/2003 9:03 PM
you should be able to. you may have to cut the post mounts/brackets out though. also will need wider regulators or go with a power setup.
I have not done it to a truck but I did it to a VW a long time ago and it was a piece of cake. rip out the vent cut the post mounts and slide a new piece of channel around the entire window.
for a window template a glass guy told me to use a piece of 1/4 masonite. install it and get it working just like it was glass then take it in to the glass shop to get the real thing.
how much did you chop your top? got any pics?
#131342 01/14/2003 11:02 PM
brothers or chevy duty one of them sells one piece glass. Its not for a chopped top but sure it will work.
grin
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces
2000 GMC Serria 1500 SL 4x4
#131343 01/15/2003 3:32 AM
Thanks for the info guys. I chopped the top eek 6" and extended the cab 20". I'm working on getting pics up here soon. Thanks again. cool
#131344 02/03/2003 4:42 AM
Junior Member
Junior Member
I just ran into a problem having cut out the vent window post on my 52 doors, You loose part of the channel that the rubber window wiper sets in..If you find a fix for this, please let me know...
#131345 02/04/2003 6:30 PM
Mac, I have the same question. If you get an answer please let me know. I'm chopping my 53 and want 1 piece windows. I have a perfect set of 54 doors that I would like to use. I just bought a set of 48 doors but they aren't nearly as solid as the 54's. You can look in the 48 doors and see an extra window channel toward the front. It would be very difficult to install that in the 54 doors. Still looking for answers.
Ron
Ron Thompson
51 Chevy 1/2 ton
36 F@rd coupe
65 Riviera
