| | | Forums66 Topics128,087 Posts1,056,000 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 35 | [b][/b] I'm about to begin the bed installation on my 1950 1 ton, 9ft bed I ordered the kit Truck has 4 cross sills plus the rear cross sill Each sill requires blocks and pads and the rear cross sill just pads The kit came with 6- 1/2" pre drilled blocks and 6 pads I need two more 1/2 pre drilled block and pads for the fourth cross sill I also got with the kit 6- 3/8 pre drilled blocks and 10 pads in an another bag Than oddly enough only 10 - 3/8 ×6" long carriage bolts with offset washers Do I even need the second kit with the smaller pre drilled holes I'm thinking about robbing a couple and drilling them out for the cross sills or am I going to need them somewhere else?
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I’m reasonably sure the rear most mounts don’t use wood blocks. | | | | | Joined: Feb 2012 Posts: 112 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 112 | On mine there are 4 sets of wood blocks.... the rear mount has a built in metal box that is part of bed that eliminates the need for a wood block in that location.
Old Truck addict 1950 chevy 1 ton napco 1956 gmc 1 ton dually napco 1954 chevy 3/4 ton napco 1957 gmc civil defense napco panel
| | | | | Joined: Jan 2006 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 35 | Which cross sills had the blocks? Do you mean all four cross sills had blocks except of course the furthest most rear one. Or that perhaps the furthest one toward the cab maybe and the furthest one towards the back? | | | | | Joined: Feb 2013 Posts: 614 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 614 | All cross sills have the blocks. The only cross sill that doesn’t is the one closest to the tail gate. That has the metal spacer | | | | | Joined: Jan 2006 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 35 | | | |
