3 members (Nick in Manitou, Hanks custodian, JW51), 106 guests, and 2 robots.
Topics128,062
Posts1,055,854
Members48,428
#1313158 06/04/2019 5:46 PM
Hello bolters,
I am trying to start my restored 1950 3100. I get no spark at the plugs. Here's what I know:
1) I have blue spark at points.
2) The coil has been tested and is functioning properly.
3) Wires are good and conduct electricity to plugs.
4) Rotor and cap have been replaced - twice.
5) Points gap is set at .022
6) Spark plugs are gapped at .035
7) Nice blue spark on plug when I connect #1 wire to the coil, ground the plug and open the points.I
All the individual components seem to work but when I put it all together - nothing.
Only thing I haven't tried is a new condenser on the distributor. That's next.
I'm running out of ideas!
Any help out there?
Jon
Jhyp #1313166 06/04/2019 6:22 PM
Condensers fail at an alarming rate these days. Find NOS or NAPA’s top line condenser. I don’t know if that’s your problem but it’s a simple, quick, inexpensive fix, if it works. 🛠
Jhyp #1313171 06/04/2019 6:28 PM
Condensers failed at an alarming rate back in the late 60s and early 70s (as I sadly recall).
Jhyp #1313177 06/04/2019 6:53 PM
Riding in the Passing Lane
Are you sure the dist. is turning?
Did you test the coil wire. Some of the early resistance wires were just in the coil wire. They failed often.
I don't think it would be the cond. if you have spark when you open the points.
1972 Chevy c10 Cheyenne Super
Jhyp #1313207 06/04/2019 11:47 PM
I would check that your rotor center tab is touching the center contact of your cap. Sometimes the metal tab on the rotor just needs to be bent up slightly to make good contact with the cap. Good luck!
Charlie
'51 3100 5-Window (Restomod in progress)
Jhyp #1313218 06/05/2019 1:23 AM
Where are you in Michigan? I live outside Saline, Michigan. If close enough, I'll come to your place and help.
Rick
1939 Chevrolet Stake Truck
