3 members (Tiny, 1955 1 Series, Hotrod Lincoln), 137 guests, and 2 robots.
Topics128,162
Posts1,056,935
Members48,458
Besides not being the favorite GO-TO spot weld cutter choice...but for those who have used them...myself included is the diameter Kosher? In other words everything I'm seeing on this site is a 3/8" hole-saw style cutter. I realize we are only talking about a 1/16" difference...but metal is metal.
So lets here your thoughts...….
H Online: Content
Back when I was teaching auto body work, we used a kit that consisted of a spring-loaded centering plunger and several hole saw type cutters that threaded onto the shank. They varied in diameter from 1/4" to 1/2" in about 4 steps. The nice thing about that setup was that the cutter could be matched to the diameter of the spot welds, and it didn't make a hole through the lower piece of metal. Once the outer panel was freed up, the residue could be ground away, leaving flat metal with no holes to fill. We could also drill a series of holes in the replacement panel, clamp it into place, and fill the holes with MIG wire.
Greetings from SE TN...gotta luv that experience can't read about and you certainly can't buy it. I will be tossing these used bits to the back of the drawer. Never even considered that spot welding in the day at the various assembly plants might have used a slightly different diameter machine???
What I see and I'm certainly guessing is something along the lines of 5/16" in the '59.
Back when I worked at a Ford plant, doing a lot of spot welding, the tips on the spot welders would wear down a little over time, so each spot welder ended up having a very slightly different diameter. I addition, how long you kept the spot welder going would lead to a slightly larger or smaller spot. Of course, now days robots are doing all of that, so I imagine there is much less variability.
Tim
I am currently digging back in to a 1953 3800 (one ton) with a nine foot bed. I've owned it since 1979, and drove it until 1982 (or so). My wife got me involved in restoring it back in 2002, got the body removed and the frame redone, then things came up. Now I am retired and starting again. If anyone is interested I have photos on Imagur ( https://timwhiteblues.imgur.com/ ). I live way back in the woods in the Ozarks on 40 acres at the end of a 2 1/2 mile private road.
Tim
