9 members (KEVINSKI, GMCJammer51, JW51, 66flea, WICruiser, Jon G, 3 invisible),
80
Mod | | | Forums66 Topics128,064 Posts1,055,860 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 102 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 102 | I am working on my 48 3600 with a 292 in it. I currently have an electric puller fan, because the water pump sits so low compared to the radiator. I would like to get rid of the electric fan noise though.
One thought was to look for an adapter plate similar to the 235 plate that raises the water pump. I haven't had any luck finding one though. Does anyone know if one is made? or have any other suggestions to get rid of the electric fan?
Thanks Jon | | | | | Joined: May 2009 Posts: 85 'Bolter | | 'Bolter Joined: May 2009 Posts: 85 | Just wondering do you run the fan all the time or is it temperature controlled? The ones I've seen with temp relays on them don't seem to run that much.
1949 3100
| | | | | Joined: Apr 2016 Posts: 102 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 102 | Mine runs all the time. Maybe I am gun shy about it overheating. I will look at the temperature controllers, but would like to get away from the electric fan completely.
Jon | | | | | Joined: Feb 2000 Posts: 5,205 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,205 | I have never seen a riser for the water pumps, I just lowered the radiator to help center the fan to the core. | | | | | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | Why not make a shroud to fit around the fan and draw air through the whole radiator? It's pretty basic sheet metal work that most anybody can do with a little planning, a pair of tin snips, and a rivet gun. Jerry
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | I believe that I saw Jon's truck at Home Coming. His radiator/water pump misalignment is pretty severe. I don't think that a homemade shroud alone will work unless he can lower the radiator 3-4 inches. I lowered my radiators to solve the same issue with a '49 and a '52 3100 with 350 V8s. It required cutting, reshaping and re-welding the bottom corners of the radiator support. pre-68 Dave makes the water pump relocation plates for the later model 235s for the AD trucks. Maybe you can PM him and pick his brain about making one for a 292. Carl
| | | | | Joined: Apr 2016 Posts: 1,042 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,042 | I have a duel fan controller that you can adjust on off temp, delay time on and off and set it to cut off and on at a given speed. I'm running 2 separate cooling systems and it will control them with individual settings.
| | | | | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | How about mounting a fan on pillow blocks and an auxiliary shaft, and leaving the water pump in its original location? Flathead Ford V8's used a system like that, with one belt driving both water pumps and the generator, and another belt for the fan. Any kind of electric fan system, no matter how sophisticated or gimmicky, is no substitute for an engine-driven fan. Jerry
| | | | | Joined: Apr 2016 Posts: 102 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 102 | Thanks for the ideas! The crankshaft and the water pump both have 2 belt grooves, so a separate fan shaft may be fairly simple. I also read about someone using a cookie sheet for their fan shroud. It would be a good starting point.
Thanks for the shove in the right direction! Jon | | | | | Joined: Feb 2000 Posts: 5,205 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,205 | If yours is like mine, the lower radiator hose will be a problem with the fan low and radiator high. | | |
