| | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I have an unknown rattle noise coming from front end only when driving & can really hear it on light acceleration. I've heard it could be s timing issue, but it sounds like radiator area. It's difficult to identify when it only does it when driving. I've wondered about a cracked pressure plate. Any suggestions to the first things to check? Thanks-
1958 Chevy Grumman Olson step van
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Drop the ignition timing back a few degrees and see if the rattle goes away. It sounds like you're getting a preignition/detonation situation going on, which can be very destructive to engine parts, particularly pistons. Jerry
