8 members (MickeyP, dt235sd, lumbersawyer, Otto Skorzeny, Joe H, 50Chevy3100, 3B, 1 invisible), 67 guests, and 1 robot.
Topics128,090
Posts1,056,014
Members48,430
#131284 07/30/2002 7:36 AM
This is for those of you who have put a SBC V8 into your 47-55.5 Chevy/GMC pickup.
Is there a good direct fit upper and lower radiator hoses with close to correct bends??
I do not want to use those "Universal" Things. I am using the stock type radiator so the
radiator hose fittings are in the stock location.
Let me know what you have used. Thanks
Kelly
1951 Chevy 3100
1967 RS/SS Camaro
#131285 07/30/2002 11:25 AM
if no one relys with an answer take a piece of stiff wire bend it to the configuration you need. go to your friendly parts store and ask to look at their selection of hoses for a correct fit. you'll probably have to do some trimming for lenght but should be able to find the right bends.
#131286 07/30/2002 10:40 PM
that is exactly what I did on my '40....don't forget to measure diameter before you leave. If the parts store isn't kind enough to let you look take your business elsewhere.
#131287 07/31/2002 11:21 AM
I just bought hoses for my six-cylinder swap (66 250 in a 52). The friendly neighborhood parts store let me peruse their Gates Buyer's Guide. Sequenced by diameter, it also has sketches and centerline length. They ordered the ones I picked and they worked great.
