| | | Forums66 Topics128,057 Posts1,055,815 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 57 | This is for those of you who have put a SBC V8 into your 47-55.5 Chevy/GMC pickup. Is there a good direct fit upper and lower radiator hoses with close to correct bends?? I do not want to use those "Universal" Things. I am using the stock type radiator so the radiator hose fittings are in the stock location. Let me know what you have used. Thanks
Kelly 1951 Chevy 3100 1967 RS/SS Camaro
| | | | | Joined: Apr 2000 Posts: 58 Member | | Member Joined: Apr 2000 Posts: 58 | if no one relys with an answer take a piece of stiff wire bend it to the configuration you need. go to your friendly parts store and ask to look at their selection of hoses for a correct fit. you'll probably have to do some trimming for lenght but should be able to find the right bends. | | | | | Joined: Jun 2000 Posts: 30 Member | | Member Joined: Jun 2000 Posts: 30 | that is exactly what I did on my '40....don't forget to measure diameter before you leave. If the parts store isn't kind enough to let you look take your business elsewhere. | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | I just bought hoses for my six-cylinder swap (66 250 in a 52). The friendly neighborhood parts store let me peruse their Gates Buyer's Guide. Sequenced by diameter, it also has sketches and centerline length. They ordered the ones I picked and they worked great. | | |
