4 members (DadsFirstPickup, BC59, Lightholder's Dad, Otto Skorzeny), 127 guests, and 2 robots.
Topics128,135
Posts1,056,422
Members48,441
#1312662 05/31/2019 4:44 PM
Hi. I’m new to this forum, so if this is the wrong place to post this let me know. I’m in the process of buying my first truck, a 1966 25,000 GVW, possible a C60? The brakes don’t work on it. I started looking, and found that the master cylinder is locked up. I went to Napa and asked if they could get a new cylinder and/or rebuild kit, they look everywhere, even other parts websites. They had a master cylinder that was really close but it had a neck, instead of being flat where it bolts to the firewall. So where do I get a master cylinder?
Thanks.
Big Bolt Forum Moderator
is it a double master cylinder? the top one on this link looks flat where it bolts to the firewall but, it is a double cylinder.
https://www.napaonline.com/en/search?text=master%2Bcylinder&referer=search_form-savedveh
Mike
Here’s some pictures.
I would take it apart, hone it out, and see if one of the Napa rebuild kits will have the internal parts you need. The one with the neck, I am assuming it is Napa part # 34403, shows a 1 1/8" bore. Does yours have the same bore? Will the neck hurt anything, or will it still fit in the truck? The reason I am asking, it looks like Rock Auto shows the same one, yours may have been replaced t some point and not be the correct one.
Mike
Does this have a hydro-vac unit on it as well? look at the cardone 1057577 or 1057579 on Rock Auto. those look like your master cylinder, just need to get the correct bore size.. (I looked under 1969 C60 with 327 engine)
Mike
The Cardone 1057577 Mike listed has a 1.75" bore which matches the one in your picture...
Is it Air Over Hydraulic Brakes (AOHB)?
Does it have Tandem Axles?
Engine size will help with part numbers as there are many different set-ups...
Also, the Hydrovac or AOHB Booster will be under the cab mounted to the side of the frame rail.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
The truck has vacuum assist brakes, a straight 6 engine (292?), tandem axle. The Cardone 1057577 looks right, except where it bolts to the firewall, it’s clocked wrong. And the master cylinder I have now is 1 1/4” bore.
Look at Rock Auto Cardone 1034403. very possible that is what yours was originally, and someone bored it out.
Mike
The 1034403, doesn’t have a bleeder valve. Maybe it doesn’t matter? I just want to get the right one. As you may be able to guess, I’ve never worked on a truck before.
Thanks for all the help so far.
Over the years master cylinders were often changed out to what was available. For a long time the big bore cylinders were not available and guys used the pickup ones. I would try to find out what size bore originally came with your truck and find that size for optimum braking.
ppp
Red dot, center of chest ...
You don't need a bleeder valve on a master cylinder. All you have to do is (slowly and carefully) loosen the line connection(s) until fluid comes out. Then retighten it.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
Good luck in searching for a new master cylinder for your truck. I have a 1966 GMC 5500. Yours might be heavier duty. I replaced a two chamber master cylinder (clutch and brake). The brake line led to a hydrovac unit that has also needed replacing. To get a replacement master cylinder, I needed to search to find a unit with brake and clutch bores and stroke that held the right amount of hydraulic fluid. This was done with much needed help from members of this forum. The replacement part also needs to have holes in the right places to bolt to the firewall, and you need to think about the availability of dust boots. You can find my thread for this under "Master Cylinder Frustration" by JRMunn.
JRMunn
I'm very concerned about the 1-1/4" bore being correct...that's the size used in the small trucks and I think with Tandem Axles you need a much larger bore to fill all of those wheel cylinders. It's hard to say what's been changed over the years, so what you have in hand may not be right either.
BTW, is your Tandem Axle factory installed or is it a after market "tag axle"?
The Truck Master Cylinder parts page is very confusing, so I took a photo so you could look it over and see if it helps! You need to confirm the Series...are you sure it's a C-60 and not a C-50 or C-80?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
I had a friend send me a picture of a page out of the parts book for my '69 T50 brakes. All well and good except that my truck has a heavy spring option which brings with it heavy brakes, something that was not at all obvious when I was looking for parts. I wound up getting the wrong stuff. Caution is the watch word I guess.
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
Mike B, thanks for the pictures. How do I find out if the truck is a C50, C60, or C80? I think the axle is original (take a look at the pictures).
Look on the glove box door for your serial number and give us that info, then we can figure out what you have.
OK, I've done some more research and it looks like you have a M60, not a C60. The M Series are the Tandems and the C Series are the single rear axle trucks. The M60 only came as a "trailing axle" tandem with the 292-I6 as it's standard engine and it had a GVW ranging from 24,000 to 30,000 pounds, so your 25,000 fits.
So, it looks like the Parts book calls for MC p/n 3896694 (shown on page 526). AND if I'm reading the parts book right the "KIt" for that MC calls it a 1-3/4 bore...p/n 3889707 (Wagner 46434).
Hope this helps,
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Mike, that helps a lot! Does this sound like the serial number M6336P107323 ?
Yes, that's the serial number...
M6336P107323
M = Conventional Cab Tandem
633 = 6303 series (60 Series w/ 157" wb)
6 = Year (1966)
P = Pontiac Plant
107323 = 7,323 truck built at Pontiac (starting at 100001)
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
U
U Offline
Looking at the pics of this truck I see it has upper and lower wheel cylinders. Is it possible they are the same as on my 68 c40?
Turning a 68 C40 into a Wood Fired pizza truck.
Mike, Thanks that helps a lot!
Can anyone tell me what operators manual, parts catalog, and service manual, I should get for the truck?
Thanks.
Service and Operator Manuals should be the same year as the truck. Parts Books should be a few years newer to make sure any late year changes are included it the manual.
Place an ad in the "wanted section" here on the Bolt and keep an eye on the big auction sites and you'll find what you need.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Crusing in the Passing Lane
292 pushrods covers are about 6" high compared to 230 and 250 engines, easy to observe, 292's also have side engine mounts offset.
ED
