8 members (klhansen, Shade Baby, Shaffer's1950, JW51, Cosmo, Oswald, 2 invisible),
57
Mod | | | Forums66 Topics128,075 Posts1,055,919 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 56 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 56 | Hi, I'm have put an inline 6 250 motor in my 56 Chevy Belair 2D hardtop. I want air conditioning and have installed a Vintage Air compressor bracket on the front of the motor passenger side. It is directly over the hole for the distributor. A standard HEI distributor for a 250 will not fit in that location because there is only 6 3/4" clearance space between the bottom of the bracket and the hole for the distributor. Any suggestions on what type or brand distributor that I can use that will fit in the tight space?
Thanks. | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | All of the info from vintage air says will not work with HEI dist., you have to use an old style points distributor.. You may try a dist cap for a 76 nova that does not have the coil on the cap, it is shorter and may fit.Then of course you will need an external coil.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | Is it possible to get a different or self made bracket for the a/c? | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Make some spacers to move the Vintage Air bracket away from the engine a little, or make your own brackets. Whittling and welding on steel isn't rocket science. Jerry
