Topics128,079
Posts1,055,941
Members48,430
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
Anyone know where I can find one at a reasonable price?
Is this for a truck? I don’t know recognize the part you show.
If this is for a 1946, it does not have a separate sending unit. It has a bulb,attached to a tube, that inserts into the block.
If you are looking for a temp gauge for a 1946, check
HERE .
There is also 1 on
eBay Harold
HaroldIs a restoration ever finished?
Check with Jim Carter Truck Parts. They say to call and ask if you're looking for an electric sending unit.
The sending unit in the image looks like one found on a much later (1958+) 235. I believe I have a used one as in your image that I would give you if you pay the postage. Provided I can find it! But Harold is right, a 1946 truck should have the capillary tube type temperature sending unit.
If the truck is a GMC it could have either a capillary or electric sending unit. What truck and engine do you have?
Good point...I had my Chevy blinders on! While not well articulated, the OP may be talking about a GMC.
