5 members (Bill Hanlon, baldeagle, fonz8261, 2 invisible), 350 guests, and 4 robots.
Topics128,163
Posts1,057,070
Members48,463
#1311671 05/23/2019 6:01 PM
Hi Members. Can anyone tell me where this oil is leaking from? See photos. Thanks.
what's above the oil leak? You've cut that off with the camera
1953 Canadian GMC 9314 w/ (factory) Chevy 235
Most likely, the valve cover is leaking. I can't think of any sort of oil passage between the block and the head that's anywhere near that side of the engine. Check to see if the bolt hole in the valve cover right above that area has a dimple in it that's not allowing the valve cover gasket to seal properly. They almost always get overtightened and distort the sheet metal, and oil leaks from ahead and behind the bolt hole since the gasket doesn't get compressed properly.
The manifold is above the oil leak.
After close examination I really can’t see the valve cover leaking.
We have a UV light and an oil additive that makes the leaking fluid glow bright which in turn makes tracing the leak back to the source much easier. This system was originally for a/c systems but now used for anything liquid. Takes just a tiny bit of the additive. google uv oil leak detection and get lots of hits.
Evan
need better pics of the top of the leak??
As asked above: where does the leak start - where is the top of the leak?
Does the leak start at the head gasket?
Looking at it closely I can’t tell, that’s the question. What are the possibilities? Head gasket??
As others have suggested, it may be the valve cover gasket. If we had detailed pics of that area.........
Craig
If it is the valve cover gasket, above the side/area of the leakage marks, there should be leakage marks visible on the upper edges/sides of the head?
You should be able to see it if it is the valve cover leaking. Now sometimes the fan can blow oil from a leak say under the front of the valve cover, down along the side. If you suspect a head gasket problem, I would suggest re-torquing the head bolts.
1951 1 Ton Completed
