6 members (1955 1 Series, 53again, Cosmo, Hotrod Lincoln, mason86, Gray_Ghost), 100 guests, and 1 robot.
Topics128,068
Posts1,055,883
Members48,428
#1312003 05/26/2019 4:07 PM
Hi Members
49’ Chevy 3100 truck here. What are the specs on oil type for 4 speed manual transmission?. How many much oil would it take if I wanted to change the transmission oil? Thanks.
A lot of info here for you.
http://www.novak-adapt.com/knowledge/transmissions/manual/sm420
Capacity is 5.5 pints. I place the transmission in neutral and remove the shifter for this task, much easier and less mess.
Thinks it’s 6 pints not qts.
The oil spec has been discussed at length prior. These two links pretty much covers it:
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=754741&page=1
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=1103664
