3 members (Materman, blanch53, 1 invisible),
125
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2018 Posts: 80 Shop Shark | | Shop Shark Joined: Apr 2018 Posts: 80 | Hi Members
49’ Chevy 3100 truck here. What are the specs on oil type for 4 speed manual transmission?. How many much oil would it take if I wanted to change the transmission oil? Thanks. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | A lot of info here for you. http://www.novak-adapt.com/knowledge/transmissions/manual/sm420Capacity is 5.5 pints. I place the transmission in neutral and remove the shifter for this task, much easier and less mess.
| | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 |
