1 members (Gray_Ghost), 65 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#1311950 05/26/2019 1:13 AM
Hi, I'm have put an inline 6 250 motor in my 56 Chevy Belair 2D hardtop. I want air conditioning and have installed a Vintage Air compressor bracket on the front of the motor passenger side. It is directly over the hole for the distributor. A standard HEI distributor for a 250 will not fit in that location because there is only 6 3/4" clearance space between the bottom of the bracket and the hole for the distributor. Any suggestions on what type or brand distributor that I can use that will fit in the tight space?
Thanks.
All of the info from vintage air says will not work with HEI dist., you have to use an old style points distributor.. You may try a dist cap for a 76 nova that does not have the coil on the cap, it is shorter and may fit.Then of course you will need an external coil.
Tommy
59 apache 1/2t
261 short stepside
Is it possible to get a different or self made bracket for the a/c?
Make some spacers to move the Vintage Air bracket away from the engine a little, or make your own brackets. Whittling and welding on steel isn't rocket science.
