| | | Forums66 Topics128,082 Posts1,055,964 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | Bolters- Based on information from the archives, I've spent some weekends picking through the region's boneyards in search of a tilt steering column from a late '70's Chevy/GMC van, specifically looking for a column WITHOUT a shifter and WITHOUT column ignition. As I am hoping to find a cheaper alternative than the ididit (or I-paid-for-it) columns that would work here, I'm wondering if anyone has any experience with internet parts locator services. What was your experience? Who would you recommend? I've spent time browsing ebay without luck. I appreciate your tips! Thanks-51PhatBoy | | | | | Joined: Nov 2001 Posts: 11 Junior Member | | Junior Member Joined: Nov 2001 Posts: 11 | Good luck on finding a van column without the shifter, they only are to be found on manual transmission vans and GM produced very few. I gave up and used a column from an auto trans van and removed the shifter. Then ground off the warts and filled the hole with JBWeld, sanded down and painted the column and collar with wrinkle black. Looks factory. Now I'm fiddling with trying to build a banjo wheel with a GM spline to top off the column with. | | | | | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | oldbones-
Thanks for the input. I may be following your lead soon! 51PhatBoy | | | | | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | oldbones-
Thanks for the input. I may be following your lead soon! 51PhatBoy | | | | | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | 51phat, if you're planning on using a tach in your truck, those leftover "ears" from the shifter would make a fine place to mount it. Oh yeah, I've had one of those columns squirrelled away for over 10 years-I paid $50 for it back then, they're getting harder to come by every day! You might try a local boneyard where "The Good Ol' Boys" go-you know, one with little turnover? Give it a shot-you might be surprised! Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
| | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Why a van column? Not many vans had floor shifters that I am aware of. Need a Fird for that. Plenty of bigger 3/4 ton or up trucks had 4spds, why not one of those? Course, then most of them didn't have "pussy" stuff like tilts?!! Even one from a mid-size car, like Monte or Cutlass should be about the same and they had floor shifts in them. Hard to find column in yard that isn't loose or shot or it wouldn't still be there. I've seen some for muscle cars at swapmeets going for over $100 and no bargaining. Most I've paid is $40, but then had to dig it out, in the winter. Take wire cutters, leave the contacts on the column and cut the wires past the connectors in the harness farther, thusly saving the connectors.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | GLP- This is a good tip. I want to stick with the dash ignition switch and was thinking that I would need a column out of truck to get that feature. I will keep my eyes open in the boneyard to see if something long enough and still cherry from a passenger vehicle would work. Spent a recent RAINY winter day looking at dashes recently. Why didn't I think of this in July!??! With thanks, 51PhatBoy  | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Vans have dash-mounted ignition key switches
